LA211 hydraulic line problem
FredC
BX2200 LA211
Dec 7, 2016
Frankford, Delaware
I replaced 2 hydraulic lines on my LA211 loader witch is connect to my BX2200. I am using a 4 position control value kit (BX2014) to operate the loader. I think I may have switched the tank port line and the pump port line. My question is does the pump port line attached to the control value on the inboard fitting or the outboard fitting.
dandeman
BX2230, LA211 FEL, RCK60B Mower, GCK60BX Bagger; Ford 4000, bush hog, blade, etc
Aug 9, 2013
166
Chapel Hill, NC
www.dan-de-man.net
Per the diagram below and checking the LA211 lines on my BX2230, the Pump Port (B) goes to the inboard side of the valve and the Tank Port (C) is connected to the outboard side of the control valve that came with my LA211.
FredC
BX2200 LA211
Dec 7, 2016
Frankford, Delaware
Thanks. That is what I was hoping. That's the way I have it attached. I replaced 3 lines and the shut-off plug in the controller. Now I can't get the loader to operate at all. I thought maybe I had switched the pump port and tank port lines.
