L48 service guidance
ZBeaver
1999 l48 tlb
May 7, 2020
RI
I have a 1999 L48 TLB. Seeking guidance on changing all filters, and anything else that I should do while I am at it.
I have an owners manual on order from my local dealer, but have not been able to find the engine oil capacity. I plan to use 10w 30 diesel oil, is there a certain brand or rating I should confirm a product meets?
it was recommended to me that I change the front axle fluid, I am prepared to do this.
I have a HST filter and two hydraulic filters, can I replace these with out draining all of the hydraulic oil? Will I regret not changing hydraulic oil, is it acceptable to just top up after replacing filters?
Any information is greatly appreciated.
3,293
Why do I think you have posted the same essential question several times? Actually because you have.
Click on your user name and you can review your previous posts and any related responses you might have received.
In the meantime, measure what comes out and put that much back in. Then use the dip stick to fine tune the level.
