Working on an L48. Cranks but won't start. Removed fuel shut off solenoid and it fired right up. Tested solenoid isolated from machine and it works as it should. Only have 1.5v to solenoid connector pins at both key on and cranking/running. Do not hear solenoid click with key on. Checked all fuses and grounds. Swapped controller under dash with known good controller. No change. Can only find wiring diagram for older serial# machine. This is the newer style with two seat switches and the opc controller under the seat. Read a post regarding this from 2019, but was never updated with resolution. Please help.
