L4701 only clicks
Jday
Kubota l4701
Jan 4, 2022
81
66
If anyone can FaceTime me and get tractor started I will Venmo you money. Just clicks been running great zero issues now just clicks battery is good.
JimmyJazz
1,262
794
Pittsburgh, Pa
In the old days I would tap the starter with hammer . This on occasion worked. Certainly not a long term solution. Sounds like your battery is kaput. Take it to an auto parts store and they will check it for you. If it needs replacing measure it and maybe head to Walmart as has been advised here. Good luck
ThaiL4508
L4508DT
Jul 30, 2022
Thailand
Double check whether your PTO is engaged. Dash would light up, I could hear some clicking, connections were all clean, charged battery all night...I had moved the PTO lever out of the way (engaged) while working on hydraulics. Started right up when I disengaged the PTO.
Jday
Kubota l4701
Jan 4, 2022
81
66
Pto is definitely not engaged. It’s in neutral, brake is on, hydrostatic is in neutral. So if was safety thing it wouldn’t click? Lights all come on including headlight, hooked up to jumper cables with truck same thing I don’t think battery. Maybe relay somewhere?
Bark
L4701/FM2560LA765/BB2560Pittsburgh disk Titan P forks
Feb 18, 2020
202
55
North CA
Might be time to try (with the key off and gear in neutral ) going straight to the starter with jumpers and see if it turns over.
Jday
Kubota l4701
Jan 4, 2022
81
66
Thanks for help guys, I don't think it is a battery issue. It hasn't shown any signs of being weak, lights work, etc. It is a HST. I don't know how to jump it between starter and battery. The way it sits in the tractor doesn't seem near what I think is the starter. Anyone have a diagram of where I could find the starter on a L4701
5,163
Tractor batteries are often not near the starter!
Seems like at a minimum, you REALLY do need a WSM........for diagrams, pictures, and descriptions!
DrankTheOrangeKoolaid
M6800/M920, Case 780B
Sep 24, 2019
99
34
Alberta
I went through this a few days ago.
I would recommend that you do the voltage drop tests. I you don't have a multimeter then do as others have suggested and clean the battery posts and the connectors at both ends of the battery cables.
I will attach the test procedure so you won't have to search for it.
GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
Nov 17, 2014
255
89
Jefferson, Ohio
3,398
Next time it starts…. send me money. :p
5,163
How do you KNOW that the ..... "battery is good"?
