L4400 Stuck in 4x4
RichK313
L4400
Jul 30, 2019
Lakeland
Forgive me if I didn't search in the correct spot but I couldn't find the answer to my question.
I have a 2005 L4400DT 800hrs that is suck in 4x4. The 4x4 shifter moves freely up and down (up 4x4, down 2x4) I followed linkage to side of transmission case and it all moves freely. Can someone point me in the right direction?
Thank you
2,312
Can you verify that the shaft into the tractor is rotating with the handle? Or has the handle come loose and is not moving the shaft?
SidecarFlip
Banned
558
If it is moving the shaft you have an internal issue. Broken shift fork most likely.
I'm sure Wolfman will elaborate...
RichK313
L4400
Jul 30, 2019
Lakeland
Thank you for the reply. Yes I can confirm the shaft stub sticking out of transmission is rotating. I was thinking it might be internal also, just hoping it’s not going to require splitting the tractors
