I have been struggling to keep the heater blower motor working in the cab of my L4240 tractor. It is a high hours machine that (from the state of the airways) has seen a lot of dust build up over the years (it is a 2013 machine).
I have taken the roof off along with the top cover of the air conditioning enclosure to take a look. Whilst I can remove the fan impeller it is not possible to remove the motor itself as it appears the fixings for this (and removal) is from below i.e. the cab headlining side.
I have managed to keep the motor limping along by dropping a few drops of oil onto the top bearing and along the motor casing inside enough to run down to the bottom bearing. This does enough to get a working fan (all speeds) for a month or so before it starts to bind (slow up) again.
I really need to change the motor but I do not want to drain the coolant (heater and hoses) nor the air conditioning circuit in order to remove the whole air conditioning module.
Does anyone know of a way to change this motor without such drastic measures?
Thanks
Thanks
