Had a tree fall across my steering wheel and bent the wheel, and bent the shaft down. Still operable, but does anyone have the part number for the steering wheel or a parts diagram for 3901 steering assembly?
The assembly is bent down around 1 inch. I have not disassembled but looking at the components I don't see any deformation in the mounting brackets or frame that holds the column assembly but something has to be bent downward. Any guesses as to what failed and where to start to get the column back to spec? I would attach pics but all it would show is the dust cover 1 inch lower than it should be (will no longer seat and electronics underneath exposed slightly) and the dust line where it once was. It functions fine with no drag. I feel lucky that is all the damage it took. Probably sounds nitpicky, but it will bother me to not fix it.
