L3901 FEL hydraulics
Chrys87
L3901
Jun 21, 2016
11
FL
Hey guys, I have a L3901 (134 hrs) with a FEL used mostly for mowing and light bucket work on our property. One of the front hydraulic arms has developed lateral excessive play on the silver pivot point (bushing). I grease everything as directed every 8-10 hrs, but now it wont even hold the grease. I asked my dealer about it and was told that the tractor does not have bushings.... Was told to bring it in, so I did. It then sat for a week then was told it would be another week or longer before they could look at it.
Anyways are these silver pins/pivot points a wear and tear item or is there a way to tighten the arm? The bucket and hydraulics work without any other issues.
I attached a pic if it helps.
Thanks
Wild and Free
B2150 HSD w/Case L340 fel 68" quicktach bkt, 60" jinma snowblower, box scraper
Oct 25, 2012
390
North Dakota
Side to side movement is normal, sorry to say you hauled it in for nothing, if it develops a lot excessive of play in the pin to bore then you have issues but nothing to worry about laterally.
