T Tn1977 New member Mar 1, 2013 31 0 0 Waverly,Tn Jul 3, 2013 #1 Anyone had any issues checking trans fluid. Sometimes mine shows in sight glass and sometime it doesn't. Thanks
B Bluegill New member Equipment L3750DT Shuttle, L3800DT FEL both Jan 11, 2012 1,560 3 0 Success Missouri Jul 3, 2013 #2 Tractor has to be level. Mine shows overfull with the front of the tractor slightly downhill and and nothing with the front slightly uphill.
GWD Member Equipment M7040, L48 TLB, BX2200 Jan 8, 2010 792 14 18 Northern California Jul 3, 2013 #3 If you can see oil in the sight glass, even sometimes, then the tractor will be fine. There is a large "fudge factor" in the HST transmission and even more in the geared. I say there is no problem. Now, if you can never see fluid then remedial action is required.
