l3800 front tires toeout
bludweiser
pennsylvania
hi people,,had my machine for a few weeks now,, done quite a bit of work,,was looking at front of tractor from a distance and noticed the right front tire is really toed out more than the left,,its real noticeable,, i know the toeout is in the casting,,are the front.tires suppose to be toed out so much,,thanks..
Bluegill
Jan 11, 2012
1,559
Success Missouri
I believe you're talking about the 'camber'. Tires tucked in where they meet the ground and set out at the top. Not adjustable and should be same on both sides. Actually I don't see how one side could be different from the other, because like you said, it's in the castings.
Toeout/in is adjustable in the tie rods
The L3800 does have a lot of positive camber.
