G GAkubota New member Equipment L3700su Feb 21, 2011 2 0 0 sylvania ga screven Feb 21, 2011 #1 I have a L3700su with less than 25 hrs. No power to ignition or hazard/headlights. Checked all fuses, battery checks OK, battery ground cable to chassis OK, all systems in neutral position. Any suggestions would be greatly appreciated.
eserv Well-known member Equipment BX24, A1000 Kubota Generator May 27, 2009 2,187 170 63 Hardisty, Alberta Feb 21, 2011 #2 Did you check the slow blow fusses by the positive terminal of the battery? These are most often blown by reverse polarity when boosting the tractor.
G GAkubota New member Equipment L3700su Feb 21, 2011 2 0 0 sylvania ga screven Feb 21, 2011 #3 I did check the fuses located near the positive batt connection. Thanks
