finally had a free weekend to knockout a few projects that have been waiting . So i fabbed up the brackets with a weld on standoff and bent some 2” flat bar. Made a prior run to the dealer for front and rear switches .($$$) jeez !! Those puppies are pricey !! Lightbar is a 30” single row unit from Tractor Supply. Spec sheet says 122 watts and they are pretty spot on with that as a quick check with my amp probe shows a 10.1 amp draw when on . Hmmm… from what i’ve read, this switch [or relay] is operating right at its current limit . I’m going to play it safe and install its own relay. Anyway , just needs a different wiring configuration but i’m diggin it !
