How hard would it be to rewire my tractor? Just the major wiring not lights. Electric is not my forte.
I haven't looked into a new harness yet. I think I might have a failing safety switch somewhere. I'm not sure if this is true, or where to look. Id like to check this first.If you have the schematic or the old harness it won’t be too hard. You may have to use different ways to connect to the back of some of the instruments.
I was able to buy a harness new from the dealer but it was expensive. Have you looked into that?
I have a schematic, it shows the safety switch on it. When I start L355SS shuttle shift, I never have to depress my clutch. My tractor is about 40yrs old. I haven't been able to find out the year it was made so far.Do you have any schematic of the wiring? If not I can see if I have one in a manual I have.
I think the only safety switch is for the clutch. It is probably on the right side (opposite the clutch pedal) and has a plunger that gets pushed in by a tab that moves when the pedal is depressed. On my L185 the switch is mounted wire the plunger pointing down.
I will try to get you a simple schematic of the basic wiring you need to look at or replace.
Would you be able to post the schematic on here?I have a schematic, it shows the safety switch on it. When I start L355SS shuttle shift, I never have to depress my clutch. My tractor is about 40yrs old. I haven't been able to find out the year it was made so far.
Sure, here it is.Would you be able to post the schematic on here?
Yes that's me. Right now, with a new battery it seems to be starting and running, so far. I really have been able to put it into service because I still have something going on with hydraulics. Low gear I can barely move, High gear I make it maybe 20ft, then it stops moving, I reverse just fine, go forward a bit and then stops again. I have cleaned the plunger in the flow control valve, seemed to help and then back to the same problem. Wiring might be a winter project. I sure want a new tractor, but this has a strong engine and its paid for.I only see the one safety switch on it and it is similar to my l185. Simple and straight forward really. The wire size is a metric size designation that I have to recall but that is the numbers beside the color designations.
You’re the same guy with the really bad wiring with the odd solenoid involved, correct?
Are you trying to repair the harness you have or replace it with new wiring totally?
