Hi everyone,
I am brand new to this site, but not new to my L35 with BT900 back hoe. I have an issue I hope someone can help me with. when I try to raise my main boom on the backhoe, it will make a click sound and then fall to the ground, unless I pull it back very slowly and gently then it will come up all the way but the more stress you put on that hydraulic ram (stick boom fully extended) the more it doesn't want to lift. Fluid levels are good and nothing is leaking. It is sort of a controlled fall, similar to putting the front loader into 'float' I can take video if that would help. thank you!
