2003 L3430 GST with 1430 hrs engine stops suddenly without warning and without pattern of activity. 2 warning lights come on after the engine quits: engine oil pressure and battery charging condition. Attempts to start engine is unsuccessful until a click heard near the engine solenoid (?) right side of engine. Engine will then start and run for various amounts of time until it shuts down suddenly without warning lights on the ECP. Have followed the work shop manual to trouble shoot the oil pressure switch for continuity and the oil pressure switch wiring harness with voltmeter and ohm meter. I can start the tractor with the oil pressure lead switch disconnected yet the engine will again shut off. What am I missing here? Considering checking the Main switch for continuity, PTO switch for continuity as well as the shuttle switch and OPC. All appear to have been functioning fine. The battery is new as of April, connections clean as well.
Appreciate any help.
