L3301 error code P2294 common fuel rail sensor replacement
CO kubota
L3301
Jul 17, 2025
Colorado
Hello all,
I joined the forum to address an issue that may help others. I struggled with the P2294 error code and the related advice to replace the common fuel rail as a cure. As you are probably aware, Kubota does not sell the common rail sensor separately. It comes with the rail assembly with a $1500+ price tag (plus installation). Kubota says the limit sensor (part of the rail) must be replaced also and that is why they do not offer separate parts.
I purchased a supply pump and suction control valve along with the rail sensor to repair my L3301. Oregon Fuel Injection has great prices on Bosch parts. For example, the SCV was $130 compared to $600-800 from Kubota.
The pressure sensor part number is 0281006396 and widely available from $40-90.00. Just remove the dash, tank and tank pan. Then disconnect the sensor pigtail and use a 27 mm deep socket to remove and replace the rail sensor pigtail.
The normal disclaimer: while this worked for me and saved thousands of dollars, I can’t guarantee it would work for anyone else. Just some ideas to help you make an informed decision.
