l3200 rear width option help
cdub
alabama
Purchasing new l3200 4wd with FEL....i cant decide between the rears being 56 inches across or 60. Ill have a 5ft bush hog, disc, bb and loaded tires. Tires are AG. I just want to know what is kosher, I know wider is more stable but 4 inches isnt much and that would run my tires paralell to my bush hog instead of 2 inches inside cutter with a 56 width. i wont be planting, just disking and bushogging and chores so i dont need a defined width for rows. Please advise
tempforce
B2650HSDC
Jun 23, 2012
387
bastrop, tx
how much of a slope are you dealing with?
if you're fairly level ground, don't worry about it….
if you are on good inclines, set er up wide.. flip the rims out, and if available use the spacers...
cdub
alabama
No crazy inclines, but my concern was having my implements stick out a little bit in the back to make it easier to get close when cutting a along a fence etc
It's being purchased so there is no effort involved in switching them myself since it will be for initial setup
