L3200 PTO won't disengage
KBorange
Kubota L3200
Aug 11, 2013
44
Eureka Missouri
Did some brush hogging for the first time this spring a few hours ago. When I got done, I couldn't get the PTO to disengage. The lever moves freely, but in the off position the PTO still operates. Any suggestions what to look for?
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,501
1,726
Near Lancaster, PA, USA
Mine did that once. After lubing the lower end of where the cable goes, all was just fine. Sorry I can't provide a detailed description of "where the cable goes" but I can't get a clear picture of it. That was a year or two ago and apparently my brain purged the image:)
bryanduke
20
US
I had an L series that did that. I took a can of WD-40 and sprayed it on the top of the cable as well as lubricating the bottom side of it. After that, it became a part off my regular maintenance and I would lube it regularly.
Grandad4
Apr 5, 2016
380
123
Greensboro, NC
Mine had the same problem years ago. There was something in how the cable was attached at the transmission that was not releasing properly. 5 minute fix; no problems since.
apeckham
L3800HST, Buhler 6' Finish Mower, Land Pride APS500, Land Pride RB3774
Feb 24, 2014
52
Corning, IA, USA
Had the same issue with my L3800. Found the arm, where the lower end of the cable attaches, was very stiff. The arm goes into the transmission case. Sprayed some lube and worked it a little and it freed up. Now part of normal maintenance routine.
Widefat
L3200
Oct 31, 2015
Virgina
This just (this week) happened to me as well on my L3200. I had just finished a long spell of bush hogging. The cable would 'pull' to engage, but not 'push' to disengage. Some Silicon spray took care of it.
