L3200 hood wont open
cadley
L3200 mfwd
Sep 29, 2023
georgia
my 3200 hood latch ….i pull hard as possible but hooe doesnt open….what an i do to get hood to release?
old and tired
1,919
1,297
Are you twisting it in the correct direction? look at the arrow...
Edit: Now I remember... the upgrade from the L2800 going to the L3200 was the hood latch to the side and a radiator screen that also sides out the side... instead of having to remove my air filter everytime I wanted to clean it (...I could really use that one!!!)
JasonW
602
369
Al
Should be a straight pull. No twisting. Might try pushing the hood back down and trying again, something might be stuck/rusted in the mechanism
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,021
2,521
Near Lancaster, PA, USA
My L3200 went away a few years ago, but I think that there was a hood ornament that had to be twisted. Also think it had an arrow (diamond?) showing the direction. Try pushing down on the hood while twisting the chrome thing.
Jim L.
872
172
L3200 hood latch has a pull to the outside located on the left side of the tractor, under the front of the hood. Basically a wire with a loop for a finger to pull, and an L at the other end to shift the latch off of a pin. If you can't look at the parts diagram, I may be able to post a picture.
If the pull is broken, then a length of wire with an L at the latch end, and catch the hole in the latch mechanism with the L. Latch must move to the outside direction to disengage from pin on hood.
