L295DT - Can't engage gears
Nancy
L295DT
May 9, 2012
10
Saxonburg, PA, USA
Tractor was working fine. Climbed a hill using lo on the hi-low lever. Stopped at top to adjust brush hog. Got back on, moved hi-low lever to hi with gear shift in first gear. No movement. Can't get the tractor to move. Seems like it might be something with the hi-lo lever. Any suggestions on what to look at and try?
3,186
Try lo instead of hi?
3,186
Verify that the handle is actually rotating the shaft into the tractor. You may have sheared the pin that connects the handle to shaft
coachgeo
Nov 16, 2012
2,459
37
Southern OH
Yeah sounds like your between Low and High so nothing is engaged. Go back to low. If that works get off the hill first. Sometimes you got to do like the old 4x4's and once on flat ground..... back up some to unbind the tension on the whole drive gears. Then put her in High.
Report back your success.
