L295d clutch help
Cknight
L295d
Aug 1, 2014
Louisville ky
I recently purchased a l295d not running, I have it starting great now however when you press in the clutch it makes a whining noise (guessing this is a throw out bearing) and will not disengage to allow it to go in gear. I needed to move the tractor to another shop the other day and was curious if it would pull its self so I picked up the rear with a bobcat put the tractor in gear then started it, I then sat it Down, it drove and pulled just fine so all issues seem to be in the clutch. I'm hoping maybe adjustment. Thanks for any help
1,015
The clutch plate may be rusted to the flywheel so it is really engaged all the time.
There are methods on breaking it loose with out splitting the tractor to get to the clutch. Use the search function.
I can't recall the process exactly but it did not seem to too difficult to try.
