L2850 with 400 hrs smokes
nickythewhitedog
l2850fl5002560
Oct 3, 2010
seattle
Previous owner did not maintain the fuel filter. Filled with alage.
Plug the injectors and loaded up the exhast system.
I have replaced the injectors and drained the fuel tank, refilled and replaced all filter. Replaced the thermosate and coolant. The temp gauge gets up to the mid point now but i still get lots of smoke when running constant RPM's
Any Ideas?:confused:
SpudHauler
RTV 1100 CW-A
Sep 8, 2010
97
My experience with gas lawnmower engine when overfilled with oil, would smoke huge amounts. Then when the problem of oil level was corrected it took quite a long while for the exhaust pipe to clean out and would smoke quite a bit until it did. Perhaps you have the same kind of condition, but with the exhaust being full of raw diesel. If so it should clear in 2 or 3 hrs of running.
kuboman
721
Smokes??? black, white, blue? What color is the smoke and how much. My guess is you have worn fuel system parts. IE: injectors and or pump.
