L2850 axle question
Dodging
Plainville ct usa
Hi, I have a l2850 and need to replace the plug seals on the bottom of the front axle. Should I put ant gasket maker or sealant on the new plug seals?
thanks
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
689
299
Herald Calif.
You should not need any sealer on the rubber plugs. Just be sure that everything is clean and shiny before installing. Including the area where the lip of the plug will rest. Good luck
