L2800 Tachometer Reading Half
bhippe
Bremerton, WA, USA
The tachometer on my L2800 tractor is reading 1/2 of the actual rpm. I have pulled off both ends of the cable and do not see any obvious damage.
Ideas?
Thank you
8,264
Could be some worn gears or missing teeth in the unit where it bolts to the motor. Easy way to tell is disconnect the cable at the motor side and gently hook a screw gun to the end of the cable and see if the tach works. It pegged mine when I checked it last week :)
Lostdutchman
L2850
Dec 31, 2013
45
Alaska
Where does the needle rest when it is shut off? My 2850 was pointed straight down. I took the tach apart and adjusted the needle to point to zero when the metal piece behind the face hit it's internal stop. When I put it together it indicated max rated rpm at full throttle.
kuboman
721
The tack drives off the front of the gear case with a 90* angle drive which likely increases the speed by twice. I'll bet it has been changed. Or, your tach needs lubrication!
