With the cooler weather today I started bush hogging a section of my property that I only do around this time of year. Anyway after a couple hours of cutting I took a brake and when I went back to work the PTO would not engage. Upon closer inspection I could tell something was wrong as the PTO shaft was very loose. After taking the plate off the rear you can see from the picture what I found. I am hoping this is an easy fix by just replacing the broken parts. Anyone ever do this before and is it as easy as it appears? The shaft and the adapter piece appear to be fine.
