Those cylinders look like new, almost. Clean them up and hone to deglaze them, then measure them. I think standard pistons could work.
I can't see where it has any broken rings or scored cylinder walls.
Mine was waaaay worse. My compression was so bad it started on one cylinder with either only and picked up a second cylinder above 1500 rpms. FYI I didn't either it, I bought from "either man"
Pretty sure it'll run like new when your done.
Only way to add power beyond original factory rating would be add fuel and timing adjustments. I doubt anyone around here would recommend doing that though. I'd leave it stock.
Good luck.
Good luck.
