L2402dt clutch problem
takattack
L2402DT-M
Mar 31, 2009
30
Sparti Greece
my l2402 was sitting on the field for about 3 weeks. today i noticed that i cant put gears on when the tractor is working. clutch is not working at all... do you think is stuck on the flywheel? i looked throught the tunnel and everything is moving ok... what can i do?
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,187
170
Hardisty, Alberta
You'll have to pull the tractor with the transmission in high gear and the clutch disengaged. Should come loose right away.
Ed
