L2002DT oils and lubricants
mattlataillede
ZL2002DT
May 5, 2020
Corsavy
Hi all
Just joined as after many searches ended up on this great site!
I have a L2002DT, actually it says ZL2002DT on it which I'm assuming means its a grey market import (has japanese writing on it).
Anyway, I've changed the engine oil no problem but am wondering what other oils I need and levels.
There is a filler cap just forward of the seat which I'm guessing is the gearbox/transmission to the rear gearbox? I can see the drive shaft when I open it. There is some oil in there but not reaching the drive shaft.. So not sure there..
Then I guess there is the rear diff and PTO, are these the same oil?
Just want to make sure it's got everything it needs, been searching online for a service manual but can't find one.
Any help from an actual owner would ease my mind!
Many thanks.
axeman87
Kubota L2002DT
Oct 30, 2015
Fort St John, BC, CANADA
I have one of these as well and not very familiar with most of it .
On the left side there if a little sight glass, it's fast to overfill.
Did you find a service manual?
I have a parts manual All in Japanese
Roadworthy
L2501 HST
Aug 17, 2019
1,647
527
Benton City, WA
John Deere sells a dye for hydraulic fluid. It improves the ability to see it in the sight glass.
