Have an apparent sleeve missing from the right side of my tractor and when the engine in running I believe you can look into this vacant hole and see the flywheel turning. Don't know what happened, there is another similarly sized plug just above the teardrop flap as per the pic but still seems to be in place. I need to fix as oil is leaking from this hole when the tractor is in use. I have temporarily capped the hole with a crude wooden plug. Any help would be appreciated, thanks.
