L2000/L225 Front Wheels...?
14karat
L2000
Jul 22, 2010
15
Hernando, MS
Anyone have any contacts on where I might get a front wheel (new or used) for my L2000?
It's a 4-hole pattern, tire size is a 12x4.00.
My current one has rusted around the valve stem and is puncturing the tube. I'm working on a temporary fix but would really like to just replace it.
I've been searching, but haven't turned up anything... yet...
I would like to eventually change out the row-crop & rice treads for some good floatation/turf treads, but I don't have that kind of cash at the moment.
Thanks for any input.
Kytim
Aug 14, 2009
848
Western Ky
try
www.wktp.com
a jap tractor salvage.
Let me know if not, I still have a jewel on the west coast. another dis-mantler
kytim
cmorningstar01
B7500HST LA302 FEL 5'Finish Mower B5100E 46" Snow Plow 22 ton splitter
Mar 27, 2011
341
81
Pemberton NJ USA
If your current rim is not to bad and only the valve stem hole is rusted would it be possible to enlarge the hole thereby removing the rusted material and use a valve stem bushing. Gemplers sells one as can be seen in the below link but you may also be able to get something at your local auto/truck parts dealer. The one Gemplers has reduces the hole from 5/8" down to 7/16"
http://www.gemplers.com/product/7G/Valve-Hole-Bushing-TR13-Valve-in-5-8-Valve-Hole
If that would not work then you could clean out the rusted area and braze in a small patch and redrill the hole to the correct size.
This site is showing a used rim for sale.
http://www.cltractor.com/clweb/Product.do?code=s.70652
If the tractor is 2wd then front tire height is not critical then you may be better off just switching over to a 14" or 15" rim with a similar height tire. If you know your bolt pattern/rim offset/load weight you can probably get a new trailer tire/wheel or an ag equipment tire/wheel setup for the price of one new or used replacement wheel.
