M Mikew22 New member Equipment L185 Oct 11, 2019 22 3 3 45 El Dorado Arkansas Jul 3, 2022 #1 How do you check the oil pressure relief valve on a L185?
TheOldHokie Well-known member Lifetime Member Equipment L3901/LA525, B7200DT/B1630, G2160/RCK60, G2460/RCK60 Apr 6, 2021 9,962 5,288 113 Myersville, MD windyridgefarm.us Jul 3, 2022 #2 Mikew22 said: How do you check the oil pressure relief valve on a L185? Click to expand... Install a pressure gauge and start it up from cold. If pressure matches the valve specification it is working. Dan
M Mikew22 New member Equipment L185 Oct 11, 2019 22 3 3 45 El Dorado Arkansas Jul 3, 2022 #3 TheOldHokie said: Install a pressure gauge and start it up from cold. If pressure matches the valve specification it is working. Dan Click to expand... Thank you sir
