Hello,
I have a strange problem; when I work with my Kubota and put the RPM above 2000, coolant is gushing out of the overflow tube (with the whistle at the end). When I put the RPM down to less than 2000, the leakage stops. I also noticed that the tractor is overheating much earlier than it did in the past. I also have two other clues: when changing the fluids a month ago, I noticed that the drained coolant contained oil. Not much, not black sludge, but when you put it on your finger it feels “oily”. Also, when I run the tractor and remove the dipstick, it will spitting oil from the hole, but I’m not shure that this relates to the problem at hand (It has always spit oil from the hole)
Does anyone has some tips on how to analyze the problem?
Kind Regards,
Anton Dorrestijn
Kind Regards,
Anton Dorrestijn
