Hello my name is Matt. I'm 23 and I've recently bought an L175 to fix up and use to plow my mom's driveway and perhaps cut our grass (I haven't decided if it's too big for our yard yet). I learned everything I know about metal and machines from my old man who I lost to a motorcycle accident back in August. After we sold his plow truck I decided we needed something to plow our driveway rather than rely on contractors and opted for a compact tractor. The build is also sort of a tribute to him.
But enough about that. The purpose of this thread is because everyone likes to watch someone else doing the work instead of them
I was going to adapt a snow blower to it but I'm having trouble finding one large and cheap enough. It needs to be at least 48" with 5" wings added on to clear the rear tires but I can't really find a used 48" so I'm considering either a cheap back blade or adapting a plow to it. We'll see when I get it running again. Once it's running and has a blade on it I'll see about some sheet metal work and a coat of paint come summer.
I got it for $1000 as is. Reverse was stripped and the steering wheel just spun. It's not pretty but it's all there and in reasonable condition. The seller ran the motor for me and the clutch and pto worked fine. I figured eh what the hell and it followed me home the next day.
First thing was to get the steering box out for a rebuild. Anyone know what went in the hole to the left of the column there? I figure I'll convert it to automotive style fuses later since all but one of the fuses had been replaced with paper clips
I didn't have a camera for a week so will be some missing pictures. I yanked the fuel tank, dash, column, and tie rod and when I unbolted the box found this.
Hummm. I didn't think I was suppose to be able to see through that, let me check the book.....
After decided that, no I wasn't suppose to be able to see through it, I looked down into the bell housing.
Looking up at me from the bottom of the bell housing was the bottom of the steering box with all the balls that had been in the lower bearing.
How it didn't rattle it's way between the pressure plate and housing I don't know but luck was with the seller when he fired it up for me. I'd seen a few on this site with cracks in 'em but I'm guessing ice blowing the bottom off is a new one. I wonder if I can weld that.....
All the water/oil that had been in the steering box had coated the everything in there and rusted most of it pretty good. I decided I had to split the tractor.
While mulling over how to do that I decided to have a look in the tranny since the top was only on finger tight (he'd had a look at reverse). Apparently he'd left the thing sitting outside without the cover on because that lovely egg nog color is produced by water mixing with oil. Great. No real harm done other than I need to flush the hydraulic system and change the fluid. Reverse is gone and the rest look a little chewed, probably because someone was in a hurry and this thing doesn't have an overrunning pto clutch. 3rd also turns a little rough but I think I can get away without replacing the shafts. I'll decide whether I really want to pull the trans later.
