L1500dt 4x4 driveshaft help
fj55-100
L 1500 dt
Oct 6, 2009
15
southwest Utah
The front driveshaft on my L1500dt has taken out the splines on the yolk that has the u joints . the one that comes off the transfer case , and has made the shaft out of the transfer case in poor condition .
I havent been able to find a part number for the shaft yolk or the output shaft from the case . does anyone know where i could find these parts .
Since the l175 did not have 4x4 , I havent found any body who is familar whis this .
Thanks
Ob1kubota
M9540DT
Jul 26, 2009
316
Birmingham, AL
As old as this Gray Market model is and no direct cross over to KAC model, if Vic can't find it, you would be better off taking your parts to a drive line fab shop and have them match up Dana Spicer yoke and U joints for your application, sincerely, Ole OB1...:)
fj55-100
L 1500 dt
Oct 6, 2009
15
southwest Utah
Thanks , not many driveline shops here , but i know a few good ones in CA .
new yolk will fix it for now . with puting a pin through the hole to stop movement . but i will still need to someday find the out put stub shaft out of the transfer case .
Or else i will be real busey re welding all the splines back ,then making a cutter to remake the splines . I have a lathe ,mill ,welders ,benders , it just looked like the long/hard way .
thanks fj55-100
osut362
M9000dtc, b7500hs
Mar 15, 2009
56
Lindale, Texas
i have a zennoh 1500fd. its a cross between a L175dt and a L185dt. when my u-joint gave up i took the old joint to the auto supply and they measured it and they had one. $22.00 at the auto supply, $87.00 plus shipping from kubota. i told them it was an L185dt and not a zennoh....al
