L1500 DT Manual Help
billrigsby
Mar 17, 2015
1,039
217
Florissant CO USA 8213'
www.facebook.com
I have found a lot of info on this forum, and received some manuals from some of the participants herein.
Thanks to those, Darren and Russell come to mind, if I forgot someone I am sorry.
I have a good grasp on what manual to use for what part of the tractor, but there are some gaps.
L175 for the engine, fuel, cooling, steering, wiring, sheet metal
L225DT for the DT (4WD) front and rear axle, final drive, transmission
L185DT for general operation
Can I assume the L175 for the clutch? since it bolts to the engine?
Which for the brakes and PTO L225DT?
Did I leave anything out?
I am trying to get a comprehensive (as possible) manual put together out of all the "parts" I have.
Thanks for your input,
8,761
Another member had run into a similar issue with the reverse being out on there l1500. The way I understood it, the l1500 shares the majority of the parts with the l175. Including the transmission. As far as the 4wd, I'm not sure. But a quick pm to service department vic should answer your question on the 4wd. :)
billrigsby
Mar 17, 2015
1,039
217
www.facebook.com
I think I will have to, a bit of checking my parts manuals, the reverse gear P/N
L1500 34150-2318-3
L175 34159-23100
L225 DT 34200-23100
L185 DT 37150-23100
I wonder how their part numbering system works? For all the US Models
the second string of numbers is identical.
