The best way is to order the tractor with them. I got 2 rear remotes and a third function for the front. I'm almost worried that I should have purchased 3 rear remotes. Now that you have missed the boat on getting them installed by the dealer on initial purchase there are other options. You can buy all the parts and see videos here linked on OTT on how to install them. First figure out what you want to run. If you want to operate a grapple on the front then get a third function kit from EA, Everything Attachments. If you want a top and tilt kit for the rear or need to run rear cylinders for other reasons, you can order the Kubota rear remotes. There are options to choose on the second and third rear remote valve. You will need to decide if these are float detent or just normal. I got my 2nd rear as a floater so my finish mower and rotary cutter will float side to side and not dig into the dirt killing the tractor. Do some searching here on OTT and you will find the answers. MountainViewHome, his user name, is a member who is particularly helpful and knowledgeable.
