jwkirkpatrick
KX41-2,L3901DT FEL,RCR1872,BB2560,RTV1120D,ZD326,MX5100F FEL,FDR3690,M108S,Z125E
Pressing the pedal does not increase travel speed. Unplugged pedal and tested switch. It works. I ohm test the wires going to the change valve and they are shorted with 17 Ohms. I check my connector plug and it is intact. I unplug it and test the wires from the pedal, no short. I test the wires going to the change valve and they are still shorted. I go under the unit and locate the wires going into the change valve unplug them and test the change valve and it shows a short. So my question is which parts do I need to replace? I don't have a WSM but I have pulled up the illustrated parts list and it looks like there is a bunch of parts in there. I was thinking just the screw and coil assembly.
