Kubota ZD 1511 72 inch zero radius diesel ReGen issues!
LMB
Kubota ZD 1511 zero radius mower 72 inch deck
Feb 10, 2024
Pulling my hair out! Mower went into regen mode with alarm blasting.and both lights blinking . Could not get it to regen. Turned the key off and on several times both regen lights went off, alarm is still a steady beep but yet mower runs normally and is not in limp mode. Should I disconnect the alarm and cut my grass or can I damage the mower. My dealer is so busy and is not able to get to it for a while. $25,000 mower and can’t cut grass!
Thanks to all!
whitetiger
Nov 20, 2011
3,111
1,542
Kansas City, KS
If you disconnect the alarm and continue to mow you turn it into a $35,000. to $40,000. mower rather quickly. There is a reason they put that loud, offensive horn under there.
Do not keep fiddling around with it, let the dealer sort it out.
