Ok, all of the following are using the tractor valve block color coded connections as the starting point since all of my hydraulic line connections from the blade are black. I lucked out and got 2 of the 4 correct the first time, so I just had to switch 2 to get it right.
1) Tractor yellow valve block to the bottom hose of the VERTICAL blade cylinder
2) Tractor red valve block to the front hose of the HORIZONTAL blade cylinder
3) Tractor blue valve block to the rear hose of the HORIZONTAL blade cylinder
4) Tractor white valve block to the top hose of the VERTICAL blade cylinder
Use the little color plastic rings, one on the valve block and the matching one on the blade hydraulic hose so that next year you can just match the plastic rings for your connections. Put these on after you check to make sure the blade moves the way you want it to. Also you may have to allow any air being introduced from the blade to purge before it works smoothly.
I made a squeegee from 2 layers of 3/8" stall mat (purchased by the foot at Tractor Supply) and use this with the "float" function of the blade to plow my gravel driveway without digging in too much. I have skid shoes but they dig in pretty badly. Then I also used a couple of zip ties around the hoses to keep any of them from rubbing on the front tire. Let us know how it goes.
