Kubota M7060
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,513
2,102
WestTn/NoMs
Doesn't look too bad. Loosen tension at alternator, thread through fan blades.
pokey1416
Jun 24, 2020
568
855
SW Michigan
I recently viewed a YT video where a belt was replaced. I can’t find it but I think it was Ryan Lynch. You could email him and ask he’s good about responding.
https://youtube.com/@ryanlynch2259
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,275
177
Coyote Flats,Texas
R&R of fan belt on M7060 appears very similar to similar task on my M7040. Loosen idler pully nut, remove belt from pulleys work belt around fan blades. Repeat process in opposite direction then set idler to apply tension on belt then tighten nut. Easy Peasy.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,513
2,102
WestTn/NoMs
That's interesting. The 7040 I looked at definitely showed the alternator as the idler. I think the difference is cab vs ROP. In any case, it's pretty straight forward.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,275
177
Coyote Flats,Texas
You're correct I had AC drive belt on my mind since I changed that belt on my M7040 a few months ago. Irregardless changing either or both belts is fairly easy. Both alternator & AC compressor belt fits around water pump/fan drive pulley.
