Kubota M7040 Cab w/ac
Four*M7040
Kubota M7040 (year 2011) Ultra Cab
Jun 1, 2025
Florida
I have a 2011 Kubota M7040 cab tractor (with a/c) and need to remove and replace the radiator. Can anyone advise step by step procedure or a website that has the information needed. Hopefully replacement can be accomplished without disturbing the a/c components. Also any recommendations on radiator vendor. thanks
mikester
M59 TLB
Oct 21, 2017
3,847
2,477
www.divergentstuff.ca
Try your local tractor dealership. Radiators are pretty basic - If you feel you need detailed step-by-step instructions to change a radiator then you probably need to hire a mechanic.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,236
150
Coyote Flats,Texas
Welcome to this forum
I suggest to acquire/read a M7040 tech manual. I think radiator on my '11 M7040 can be R&R without disturbing AC system.
Four*M7040
Jun 1, 2025
Florida
The online tech manuals that I found described many tractor repairs but removal of the radiator was not covered. The online videos and descriptions indicated different models and different configurations and usually without cab and ac. My tractor's radiator configuration does not bolt or fasten with top and / or bottom brackets but instead has a metal frame connecting to other welded metal braces which are supporting the ac components.
