Kubota LA525 front loader not working properly. Lifts and lowers slow and doesn't lift as much weight. None of the seals look to be leaking an at times you can hear a hissing sound from the control panel as if it trying to lift or lower when tractor is just ruining. Also seems to make the tractor run hot. Could cheap hydraulic fluid cause this, or does anybody know what else the issue could be ?
