Kubota l3301 issues
PerezVic_08
Kubota l3301
May 18, 2022
Mission
Hello crew. I've been working on kubota l3301 did a clutch replacement got everything back into place but I'm getting no start or click when moving ignition forward. Check pto lever, battery, fuses, wiring, seat safety switch. Idk anymore! The cluster have some codes e-93 PO335, PO380,PO336 PO193
WoodKutter
L4600 John Deere 750, John Deere 420
Apr 15, 2022
95
55
Vermont and Northern Maine
That's some serious codes! Everything was fine before the clutch work? PO 335 is as follows.
What Does Code P0335 Mean?
  • P0335 definition: Crankshaft Position Sensor “A” Circuit Malfunction (Bank 1)
  • Issue Severity: SEVERE – Stop driving immediately
  • Repair Urgency: Fix this code immediately (same day if possible) to avoid internal engine damage.
  • Diagnosis: This trouble code can cause some major internal mechanical drivability issues. To prevent any further damage to the engine, diagnosis should be done as soon as possible to fix the issue.
I would not run your tractor before a Kubota tech reads and diagnoses it.
PerezVic_08
Kubota l3301
May 18, 2022
Mission
Tractor was working fine when customer brought in for clutch replace installed everything back together and now not getting any crank or start.
