Kubota F2560 Hydraulic Motor powered Grass Catcher
MBofMB
F2560, GR2100
Aug 7, 2018
Carberry, Manitoba CANADA
I've tried 12v motors to rotate the blower (golf cart starter, salt/gravel spreader) - high heat & slow rpms. I'm thinking of using a Concentric gear drive motor, adjustable line throttle valve and 2-way HP ball valve. The motor is capable of 5,500 RPM. Line throttle would be used to adjust down to 3,600 RPM.
Kubota F2560 Lawn Tractor Hydraulics
Hydraulics Type:
open center
Hydraulics Valves: 1 to 3
Hydraulics Pump Flow: 4.9 gpm
Transmission case: 14.0 L
I'm not that familiar with hydraulics or with the F2560 setup but am willing to learn and try.
May I have any suggestions or tricks that would make this experiment a success; would be very appreciated.
Thank you for your time and efforts in advance.
