Kubota BX2750 C snowblower?
Frostbitten
2019 BX2380
Jul 19, 2012
50
Grand Haven, Mi USA
Need some info guys and gals
Came across a kubota bx2750 C snowblower
It has the quick hitch, driveshaft etc....
basically everything I need
Came off a BX2350 tractor. Should fit my bx2660 no problem
(from what i understand, the bx 50, 60 and 70 series are all the same correct?)
anyway, can you tell me the difference between the (c) model and the (d) model?
She says its about 10 years old , bought new. Its dirty but in good shape.
I want to know 2 things:
1. will it fit my bx2660 (i think it will since it came from a bx2350)
2. what is the difference between a bx2750c and bx2750d?
sagor
Jan 9, 2017
304
86
Sudbury, ON, Canada
Even between BX2750D models, there are differences, mostly small things like how shear bolts are used. The latest 2750D model has changed the fan shear bolt to a flange design instead of the "bolt thru the shaft" design.
For the most part, all the BX2750 blowers are basically the same. There may be different bolts/chains/skids/etc., but as long as you have the parts list (Kubota Parts Finder), you can maintain these easily. Make sure you use the proper, factory supplied shear bolts, especially for the older blowers.
If you don't have the chute rotator handle, that may be slightly different between models as well.
