Kubota B7500 mowing decks
cowdog
Yadkinville, NC USA
I have a kubota B7500 tractor with a RCK54-24B belly deck. I found a used older model RC60-24B deck and I just wonder if this will fit my existing mower mounting bracket. Any replies would be helpful Thanks.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
80
Rocky Face, Georgia
Do you have any idea what the RC60 came off of?
It would probably be wise idea to break out the old measuring tape and a note pad.
Rusty46
B7500 HSD-R, LA 302, RCK60-24B, Woods RB-72, Millcreek 25, Harrow, Payne PF800,
Cowdog - I do not know the answer to your question. Is the deck that you found an RC60-24B or an RCK60-24B?
I have a 2003 B7500 HSD-R with the RCK60-24B MMM. My operator's Manual shows the RCK60-24B, RCK54-24B & RCK54-75B decks used with the following tractors: B7500, B7400, B7300, B2410, B2400, B2100, B1700. The installation instructions for both the RCK60-24B & RCK54-24B decks are the same in my manual. I found no reference for using a different part for installation of one or the other, however, this manual does not show part numbers.
If the deck you found is the RCK60-24B, I suggest that you go to www.TractorSmart.com and request free downloadable PDF parts lists for both decks. TractorSmart will email the links for the downloads to you. Compare the part numbers for the brackets and other mounting parts. If they all match, you should be good to go!
If the deck you found is a RC60-24B, you might still request the parts list, and compare both parts and part numbers.
I don't know how age of the equipment might impact the comparison. What did you mean when you called the deck you found "older"?
Best wishes!
