Kubota B7300 Hydraulic issues
Greg hendsbee
Kubota B7300
Feb 11, 2026
Nova Scotia, Canada
Hi, Greg here
I’m a relatively new tractor owner. I have a Kubota B7300. It’s a 1995. It. And with a homemade backhoe attached to the 3-point hitch. When I took it off to attach the snowblower, the 3 point hitch would not raise or lower ( yes, checker the speed control valve and fluid levels), but the loader would still work. Today the loader stopped working. Would this be the hydraulic pump it’s self. Any help would be greatly appreciated… I have a lot of snow to move 🙏
6,404
Hi, Greg here
Without more detailed info I woulx guess you did not loop the backhoe hoses together disabling the 3pt in the process. That also deadheads the loader against the pressure relief and the system has been running nonstop at maximum system pressure. Apparently something finally failed under that load. Now you will need to trouble shoot the hydraulic system to locate and repair the failuer(s)
Its not that hard but it could be expensive.
Greg hendsbee
Kubota B7300
Feb 11, 2026
Nova Scotia, Canada
Without more detailed info I woulx guess you did not loop the backhoe hoses together disabling the 3pt in the process. That slso deadheads the loader against the pressure relief and the system has been running nonstop at maximum system presdure system p pressure. Apparently something finally failed under that load. Now you will need to trouble shoot the hydrauli. system to locate and repair the failuer(s)
6,404
OK - forget most of what I said in my first post.
You are going to have to do some trouble shooting to determine whats wrong.
Did you ever get the 3pt to work?
Has thd 3pt ever worked?
Make and model of the loader?
