Kubota B7001 clutch problem.!!
stavros
Cyprus
hello there, im a newbie here so this is my first question.when i press the clutch i here a noise coming from inside the clutch. what might cause this?i thought of the bush of the crank that gives movement to the gearbox because is not brand new.any opinions it is much appreciated .
thank you all,
Stumpy
L175
Dec 1, 2011
848
NE Ohio
Yep as long as the clutch grabs just fine and you only hear the noise when you've got the peddle in it's more than likely the throwout bearing. If it presents other symptoms more investigation is required. The only other possibility off the top of my head is maladjusted pressure plate fingers.
Kytim
Aug 14, 2009
848
Western Ky
+1, yeah what they said.
Also, welcome aboard!!!
