Kubota B2650 - Is it possible to use the FEL with the snowblower subframe mounted?
1971Corvette
15
Northeastern, USA
I have a B2650 with a FEL and a B2782 (63") front mount snowblower. The snowblower is easy enough to take on and off. However, I'm wondering if it's possible to leave the snowblower subframe on and remount the FEL in a pinch for limited use (for instance, to dig through a large snowbank at the end of the driveway.
DeepWoods
B2650HSDC Woodland Mills WC68 Wood Chipper
Apr 10, 2019
342
282
Bigfork Minnesota
Nope, you have to take the mount for the snowblower off to put the fel on. There isnt enough clearance between the two if the mount is left on.
6,823
Glad someone with a B2650 responded.
It seems most subframes are not compatible with the loader.
orange crusher
BX 2680
Sep 30, 2017
354
482
ontario canada
Not only do they not fit together, but you would have to deal with the plumbing issues for the hydraulics as well.
Orange1forme
B2650 HSDC, filled tires, wheel spacers, B2728B , LA534A FEL, 3rd valve kit
Dec 1, 2018
397
60
Wa
And the ground clearance issue.
With the snowblower on you tend not to go in the same places as with the FEL. You might forget the subframe is on(if it were possible) and get stuck or do some damage.
shelkol
bx-2200, Woods BH6000 backhoe, Tach-N-Go quick attach bucket, snow blower
Nov 12, 2015
206
173
Westford, Massachusetts
shelkol.com
I have a BX2200 and left the sub frame on one year. Mostly used the loader arms with a plow attached for snow. Well, got so deep I decided to put the snow blower on. The subframe was so caked with ice and it took me an hour to get it free so I could put the blower on.
Never do that again :)
