Knocking sound on D1005 that goes away with open injector line
c5vettster
lot of kubota stuff
Aug 30, 2022
51
10
Maryland
Hi folks,
New poster here. I am getting a Kubota D1005 powered generator back to life after the pump injected dirt. The pump was rebuilt but now the engine makes a knocking sound that goes away if I crack open the injector line on the middle cylinder.
here is the youtube link
What do you think I deal with? Clearly the knocking goes away when I depressurize the cylinder. A bad injector or something more sinister?
RBsingl
Kubota F 2690 72" rear discharge deck, Deere 955
Jul 1, 2022
485
566
Central IL
A stuck open or badly leaking injector can make that sort of noise. Here is a pretty good example with "fuel knock" due to stuck injector:
Rodger
c5vettster
lot of kubota stuff
Aug 30, 2022
51
10
Maryland
Rodger
You know I think that maybe it! I am going to put a new injector in
mike0000
Kubota L3901, RTV900
Sep 15, 2021
84
91
Southern Indiana
If it‘s easy to do, swap injectors around and see if the knock moves too.
that should let you know it is the injector, not an issue with that cylinder.
Mike
c5vettster
lot of kubota stuff
Aug 30, 2022
51
10
Maryland
Rodger
Thanks! It does look like this! I will change the injector and scope the cylinder this weekend
c5vettster
lot of kubota stuff
Aug 30, 2022
51
10
Maryland
Well, thanks for all the advice! It was indeed an injector! I replaced it with a spare one that I knew was good and here how she runs now.
RBsingl
Jul 1, 2022
485
566
Central IL
That sounds MUCH better! Glad it was a pretty cheap and easy repair!
Rodger
c5vettster
lot of kubota stuff
Aug 30, 2022
51
10
Maryland
Rodger
So am I. I knew it must have been something simple for these engines don't develop a deadly knock because it took 6 months to get the injection pump sorted out.
